11 years agoVHDL : Problem with 4-Bit Adder and Subtractor !
Hi
I want to make a 4-Bit Adder and Subtractor with VHDL I have created 1-Bit Full-Adder , XOR Gate ( for Subtract ) and a 4-Bit Adder as shown below : Full-Adder :
LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY FullAdder_1_Bit IS PORT( X, Y : IN STD_LOGIC; CIn : IN STD_LOGIC; Sum : OUT STD_LOGIC; COut : OUT STD_LOGIC ); END FullAdder_1_Bit; ARCHITECTURE Behavier OF FullAdder_1_Bit IS BEGIN Sum <= X XOR Y XOR CIn; COut <= (X AND Y) OR (X AND CIn) OR (Y AND CIn); END Behavier; XOR Gate :
LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY XORGate IS PORT( X1, X2 : IN STD_LOGIC; Y : OUT STD_LOGIC ); END XORGate; ARCHITECTURE Declare OF XORGate IS BEGIN Y <= X1 XOR X2; END Declare; 4-Bit Adder :
LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY Adder_4_Bit IS PORT( A, B : IN STD_LOGIC_VECTOR(3 DOWNTO 0); Mode : IN STD_LOGIC; Sum : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); COut : OUT STD_LOGIC ); END Adder_4_Bit; ARCHITECTURE Structure OF Adder_4_Bit IS COMPONENT FullAdder_1_Bit IS PORT( X, Y : IN STD_LOGIC; CIn : IN STD_LOGIC; Sum : OUT STD_LOGIC; COut : OUT STD_LOGIC ); END COMPONENT; COMPONENT XORGate IS PORT( X1, X2 : IN STD_LOGIC; Y : OUT STD_LOGIC ); END COMPONENT; SIGNAL COut_Temp : STD_LOGIC_VECTOR(2 DOWNTO 0); SIGNAL XB : STD_LOGIC_VECTOR(3 DOWNTO 0); BEGIN B_0 : XORGate PORT MAP(Mode, B(0), XB(0)); B_1 : XORGate PORT MAP(Mode, B(1), XB(1)); B_2 : XORGate PORT MAP(Mode, B(2), XB(2)); B_3 : XORGate PORT MAP(Mode, B(3), XB(3)); SUM_0 : FullAdder_1_Bit PORT MAP (A(0), XB(0), Mode, Sum(0), COut_Temp(0)); SUM_1 : FullAdder_1_Bit PORT MAP (A(1), XB(1), COut_Temp(0), Sum(1), COut_Temp(1)); SUM_2 : FullAdder_1_Bit PORT MAP (A(2), XB(2), COut_Temp(1), Sum(2), COut_Temp(2)); SUM_3 : FullAdder_1_Bit PORT MAP (A(3), XB(3), COut_Temp(2), Sum(3), COut); END; and in my Main Codes , i have used those ( like Test-Bench ! ) :
LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.ALL; ENTITY Add_AND_Sub IS END Add_AND_Sub; ARCHITECTURE Declare OF Add_AND_Sub IS COMPONENT Adder_4_Bit IS PORT( A, B : IN STD_LOGIC_VECTOR(3 DOWNTO 0); Mode : IN STD_LOGIC; Sum : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); COut : OUT STD_LOGIC ); END COMPONENT; SIGNAL A, B : STD_LOGIC_VECTOR(4 DOWNTO 0); SIGNAL Mode : STD_LOGIC; SIGNAL As, Bs, E, AVF : STD_LOGIC; SIGNAL XA, XB, Sum : STD_LOGIC_VECTOR(3 DOWNTO 0); BEGIN Add : Adder_4_Bit PORT MAP(XA, XB, Mode, Sum, E); PROCESS(A, B, Mode) BEGIN As <= A(4); Bs <= B(4); XA <= A(3 DOWNTO 0); XB <= B(3 DOWNTO 0); CASE Mode IS WHEN '0' => IF ((As XOR Bs) = '1') THEN Mode <= '1'; XA <= Sum; AVF <= '0'; IF (E = '1') THEN IF (XA = "0000") THEN As <= '0'; END IF; ELSE XA <= (NOT XA) + "0001"; As <= NOT As; END IF; ELSE XA <= Sum; END IF; WHEN '1' => IF ((As XOR Bs) = '1') THEN Mode <= '0'; XA <= Sum; AVF <= E; ELSE AVF <= '0'; XA <= Sum; IF (E = '1') THEN IF (XA = "0000") THEN As <= '0'; END IF; ELSE XA <= (NOT XA) + "0001"; As <= NOT As; END IF; END IF; WHEN Others => -- END CASE; END PROCESS; END Declare; The main scenario is to Model this algorithm : http://i.stack.imgur.com/3H6hv.jpg but now i want to have output in XA and As - I Should use registers shown in algorithm such as "E" and "AVF"
New ALU :
New Test Bench :LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.numeric_std.all; USE ieee.std_logic_unsigned.ALL; ENTITY ALU IS PORT( --Clk : IN STD_LOGIC; C : IN STD_LOGIC_VECTOR(3 DOWNTO 0); D : IN STD_LOGIC_VECTOR(3 DOWNTO 0); Cs : IN STD_LOGIC; Ds : IN STD_LOGIC; Mode_ALU : IN STD_LOGIC; Sum_ALU : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); AVF : OUT STD_LOGIC ); END ALU; ARCHITECTURE Declare OF ALU IS COMPONENT Adder_4_Bit IS PORT( A, B : IN STD_LOGIC_VECTOR(3 DOWNTO 0); Mode : IN STD_LOGIC; Sum : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); COut : OUT STD_LOGIC ); END COMPONENT; SIGNAL E, Temp_Cs, Temp_Ds : STD_LOGIC; SIGNAL Temp_S : STD_LOGIC_VECTOR(3 DOWNTO 0); BEGIN Add : Adder_4_Bit PORT MAP(C, D, Mode_ALU, Temp_S, E); -- Sum_ALU <= Temp_S; -- Temp_Cs <= Cs; -- Temp_Ds <= Ds; PROCESS BEGIN WAIT FOR 30 ns; Sum_ALU <= Temp_S; Temp_Cs <= Cs; Temp_Ds <= Ds; END PROCESS; PROCESS(C, D, Cs, Ds, Mode_ALU) BEGIN CASE Mode_ALU IS WHEN '0' => IF ((Cs XOR Ds) = '1') THEN AVF <= '0'; IF (E = '1') THEN IF (Temp_S = "0000") THEN Temp_Cs <= '0'; END IF; ELSE Sum_ALU <= (NOT Temp_S) + "0001"; Temp_Cs <= NOT Cs; END IF; ELSE AVF <= E; END IF; WHEN '1' => IF ((Cs XOR Ds) = '1') THEN AVF <= E; ELSE AVF <= '0'; IF (E = '1') THEN IF (Temp_S = "0000") THEN Temp_Cs <= '0'; END IF; ELSE Sum_ALU <= (NOT Temp_S) + "0001"; Temp_Cs <= NOT Cs; END IF; END IF; WHEN Others => -- END CASE; END PROCESS; END Declare;
But the Result have 'X' Value ! : https://www.alteraforum.com/forum/attachment.php?attachmentid=10765 Is the Process I have written in ALU for setting temp values, correct ? thank for your help Tricky ...LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.numeric_std.all; USE ieee.std_logic_unsigned.ALL; ENTITY ALU_Test_Bench IS END ALU_Test_Bench; ARCHITECTURE Declare OF ALU_Test_Bench IS COMPONENT ALU IS PORT( --Clk : IN STD_LOGIC; C : IN STD_LOGIC_VECTOR(3 DOWNTO 0); D : IN STD_LOGIC_VECTOR(3 DOWNTO 0); Cs : IN STD_LOGIC; Ds : IN STD_LOGIC; Mode_ALU : IN STD_LOGIC; Sum_ALU : OUT STD_LOGIC_VECTOR(3 DOWNTO 0); AVF : OUT STD_LOGIC ); END COMPONENT; SIGNAL Xs, Ys, M, Av : STD_LOGIC; SIGNAL X, Y, O : STD_LOGIC_VECTOR(3 DOWNTO 0); BEGIN ALU_PM : ALU PORT MAP(X, Y, Xs, Ys, M, O, Av); Mode_Process : PROCESS BEGIN M <= '1'; WAIT FOR 10 ns; M <= '0'; WAIT FOR 10 ns; END PROCESS; Calc_Process : PROCESS BEGIN X <= "0010"; Y <= "1011"; Xs <= '0'; Ys <= '1'; WAIT FOR 20 ns; X <= "0110"; Y <= "0011"; Xs <= '1'; Ys <= '1'; WAIT FOR 20 ns; X <= "0010"; Y <= "1011"; Xs <= '0'; Ys <= '1'; WAIT FOR 20 ns; END PROCESS; END Declare;
