11 years agoVHDL : Problem with 4-Bit Adder and Subtractor !
Hi I want to make a 4-Bit Adder and Subtractor with VHDL I have created 1-Bit Full-Adder , XOR Gate ( for Subtract ) and a 4-Bit Adder as shown below : Full-Adder :
LIBRARY ieee; USE i...
11 years agoNew ALU :
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
USE ieee.std_logic_unsigned.ALL;
ENTITY ALU IS
PORT(
--Clk : IN STD_LOGIC;
C : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
D : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
Cs : IN STD_LOGIC;
Ds : IN STD_LOGIC;
Mode_ALU : IN STD_LOGIC;
Sum_ALU : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
AVF : OUT STD_LOGIC
END ALU;
ARCHITECTURE Declare OF ALU IS
COMPONENT Adder_4_Bit IS
PORT(
A, B : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
Mode : IN STD_LOGIC;
Sum : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
COut : OUT STD_LOGIC
END COMPONENT;
SIGNAL E, Temp_Cs, Temp_Ds : STD_LOGIC;
SIGNAL Temp_S : STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
Add : Adder_4_Bit PORT MAP(C, D, Mode_ALU, Temp_S, E);
-- Sum_ALU <= Temp_S;
-- Temp_Cs <= Cs;
-- Temp_Ds <= Ds;
PROCESS
BEGIN
WAIT FOR 30 ns;
Sum_ALU <= Temp_S;
Temp_Cs <= Cs;
Temp_Ds <= Ds;
END PROCESS;
PROCESS(C, D, Cs, Ds, Mode_ALU)
BEGIN
CASE Mode_ALU IS
WHEN '0' =>
IF ((Cs XOR Ds) = '1') THEN
AVF <= '0';
IF (E = '1') THEN
IF (Temp_S = "0000") THEN
Temp_Cs <= '0';
END IF;
ELSE
Sum_ALU <= (NOT Temp_S) + "0001";
Temp_Cs <= NOT Cs;
END IF;
ELSE
AVF <= E;
END IF;
WHEN '1' =>
AVF <= E;
ELSE
AVF <= '0';
IF (E = '1') THEN
Temp_Cs <= '0';
END IF;
ELSE
Temp_Cs <= NOT Cs;
END IF;
END IF;
WHEN Others =>
END CASE;
END PROCESS;
END Declare;
New Test Bench :
LIBRARY ieee;
ENTITY ALU_Test_Bench IS
END ALU_Test_Bench;
ARCHITECTURE Declare OF ALU_Test_Bench IS
COMPONENT ALU IS
PORT(
Cs : IN STD_LOGIC;
Ds : IN STD_LOGIC;
AVF : OUT STD_LOGIC
END COMPONENT;
SIGNAL Xs, Ys, M, Av : STD_LOGIC;
SIGNAL X, Y, O : STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
ALU_PM : ALU PORT MAP(X, Y, Xs, Ys, M, O, Av);
Mode_Process : PROCESS
BEGIN
M <= '1';
WAIT FOR 10 ns;
M <= '0';
WAIT FOR 10 ns;
END PROCESS;
Calc_Process : PROCESS
BEGIN
X <= "0010";
Y <= "1011";
Xs <= '0';
Ys <= '1';
WAIT FOR 20 ns;
X <= "0110";
Y <= "0011";
Xs <= '1';
Ys <= '1';
WAIT FOR 20 ns;
X <= "0010";
Y <= "1011";
Xs <= '0';
Ys <= '1';
WAIT FOR 20 ns;
END PROCESS;
END Declare;
But the Result have 'X' Value ! : https://www.alteraforum.com/forum/attachment.php?attachmentid=10765 Is the Process I have written in ALU for setting temp values, correct ? thank for your help Tricky ...
