13 years agoVHDL - Writing To Registers
I want to use four push buttons as inputs and three seven-segment LED displays as outputs. Two push buttons should step up and down through the sixteen RAM locations; the other two should increment and decrement the contents of the currently-displayed memory location. One seven segment display should show the current address (0–F), and two others should display the contents of that location in hexadecimal (00–FF). This is my code to attempt to do this (I haven't implemented the display yet):
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity raminfr is port ( clk : in std_logic; we : in std_logic; do : out unsigned(7 downto 0) ); end raminfr; architecture rtl of raminfr is type ram_type is array (0 to 15) of unsigned(7 downto 0); signal RAM : ram_type; signal read_a : unsigned(3 downto 0); signal a : unsigned(3 downto 0); signal di : unsigned(7 downto 0); signal clock : std_logic; signal key : std_logic_vector(3 downto 0); begin U1: entity work.lab1 port map ( clock =>clock, key => key, register_counter => a, value_counter => di ); process (clk) begin if rising_edge(clk) then if we = '1' then RAM(to_integer(a)) <= di; end if; read_a <= a; end if; end process; do <= RAM(to_integer(read_a)); end rtl; library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity lab1 is port( clock : in std_logic; key : in std_logic_vector(3 downto 0); value_counter : buffer unsigned(7 downto 0) ; register_counter : buffer unsigned(3 downto 0) ); end lab1; architecture up_and_down of lab1 is signal value_in_ram : unsigned(7 downto 0); signal clk : std_logic; signal we : std_logic; begin U1: entity work.raminfr port map ( do=>value_in_ram, clk=>clk, we=>we ); process(clock, value_counter, register_counter) begin if rising_edge(clock) then if (key(3)='0' and key(2)='0' and key(1)='1' and key(0)='0') then value_counter <= value_counter + "1"; elsif (key(3)='0' and key(2)='0' and key(1)='0' and key(0)='1') then value_counter <= value_counter - "1"; elsif (key(3)='1' and key(2)='0' and key(1)='0' and key(0)='0') then register_counter<= register_counter + "1"; value_counter <= value_in_ram; elsif (key(3)='0' and key(2)='1' and key(1)='0' and key(0)='0') then register_counter<= register_counter - "1"; value_counter <= value_in_ram; end if; end if; end process; end architecture up_and_down; When I try to compile this, I get the following errors repeating over and over: Error (12051): Project too complex: hierarchy path is too long Error (12052): Entity "lab1" is instantiated by entity "raminfr" Error (12052): Entity "raminfr" is instantiated by entity "lab1" This is obviously due to the fact that I have port mapped each entity in the other, but I don't know any other way to accomplish what I want to accomplish. Can somebody suggest alternatives?
