12 years agoVGA DE2 VGA_Drive
HII
Ill try to convert VGA driver to DE2 bord on VHDL but it dosnt work ill post my code maybe you have any idea thanks dana code: --------------------Title------------------------------------- --Project Name: VGA_Controller --File Name: VGA_Driver.vhd -------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; -------------------------------------------------------------- -------------------------Entity------------------------------- entity VGA_Driver is port( clock : IN std_logic; --5MHz reset : IN std_logic; RGB_In : IN std_logic_vector (2 downto 0); Red : OUT std_logic_vector (3 downto 0); Green : OUT std_logic_vector (3 downto 0); Blue : OUT std_logic_vector (3 downto 0); H_Sync : OUT std_logic :='1'; V_Sync : OUT std_logic :='1'; sync : out std_logic ; VGA_CLK : out std_logic; blank : out std_logic ); end VGA_Driver; ------------------------------------------------------------ --------------------Architecture---------------------------- architecture behave of VGA_Driver is ------------------------------------------------------------ ---------------COMPONENTS DECLARATION----------------------- COMPONENT VGA_PLL IS PORT ( areset : IN STD_LOGIC := '0'; inclk0 : IN STD_LOGIC := '0'; c0 : OUT STD_LOGIC ; locked : OUT STD_LOGIC ); END COMPONENT; ------------------------------------------------------------ ----------------Signals Declaration------------------------- signal s_locked : STD_LOGIC; signal clock_25MHZ : STD_LOGIC:= '0'; ------------------------------------------------------------ -------------COMPONENTS INSTANTIATION----------------------- begin --U1:VGA_PLL --PORT MAP -- ( -- areset => reset, -- inclk0 => clock, -- c0 => clock_25MHZ, -- locked => s_locked -- ); ------------------------------------------------------------ sync <= '0'; --VGA_CLK <= clock_25MHZ; blank <= '1'; process(clock_25MHZ,reset) variable H_Count:integer range 0 to 799; variable V_Count:integer range 0 to 524; begin if reset='1' then H_Count :=0; V_Count :=0; H_Sync <='1'; V_Sync <='1'; --blank <= '1'; elsif clock_25MHZ' EVENT and clock_25MHZ='1' then --sync <= '1'; --blank <= '0'; H_Count:=H_Count+1; if (H_Count=799) then H_Count:=0; V_Count:=V_Count+1; end if; if(V_Count=524) then V_Count:=0; end if; --end if; ------------------------------------------------------- --------Horizontal Sync Signals------------------------ case H_Count Is when 0 to 95 => H_Sync <='0'; Red <=(others =>'0'); Green <=(others =>'0'); Blue <=(others =>'0'); -- blank <= '1'; when 96 to 143 => H_Sync <='1'; Red <=(others =>'0'); Green <=(others =>'0'); Blue <=(others =>'0'); --blank <= '0'; when 144 to 783 => H_Sync <='1'; Red <=(others => RGB_In(2)); Green <=(others => RGB_In(1)); Blue <=(others => RGB_In(0)); --blank <= '1'; when 784 to 799 => H_Sync <='1'; Red <=(others =>'0'); Green <=(others =>'0'); Blue <=(others =>'0'); -- blank <= '0'; end case; ------------------------------------------------------ --------Vertical Sync Signals------------------------- case V_Count Is when 0 to 1 => V_Sync <='0'; Red <=(others =>'0'); Green <=(others =>'0'); Blue <=(others =>'0'); --blank <= '1'; when 2 to 34 => V_Sync <='1'; Red <=(others =>'0'); Green <=(others =>'0'); Blue <=(others =>'0'); --blank <= '0'; when 35 to 514 => V_Sync <='1'; --blank <= '1'; when 515 to 524 => V_Sync <='1'; Red <=(others =>'0'); Green <=(others =>'0'); Blue <=(others =>'0'); -- blank <= '0'; end case; ------------------------------------------------------- end if; end process; vga_clk_gen : PROCESS(clock,reset)--devides 50MHz clock in 2, making it a 25MHz clock VARIABLE count : INTEGER := 0; BEGIN IF reset= '1' THEN clock_25MHZ <= '0'; VGA_CLK <= '0'; count := 0; ELSIF rising_edge(clock) THEN IF count = 0 THEN clock_25MHZ <= '1'; --1 period of 50MHz high VGA_CLK <= '1'; count := 1; ELSIF count = 1 THEN clock_25MHZ <= '0'; --1 period of 50MHz low VGA_CLK <= '0'; count := 0; END IF; END IF; END PROCESS; end behave;
