13 years agoI think you'll be okay with the counter. Just make sure it's a synchronous counter and not a ripple counter. As mentioned, if you're concerned about clock skew for nodes you are driving with this clock, you can put it on a Global buffer. If it has a lot of loads on it, the Fitter will likely auto-promote it to a Global anyway. If not, you can manually add it.
