13 years agoUsing a counter is usually fine for such a slow clock, as long as you constrain it with the create_generated_clock constraint. The tools will typically drive it through a clock buffer (altclkctrl), or you can do it manually. Alternatively you could cascade plls, but you'll need to phase align it to the fast clock when you do transfers
