anrfpga
3 years agoVersion Control of Quartus Projects with .qsys and .ip files
Hi All,
We are currently dealing with large designs with HPS connected to multiple Intel IPs along with our custom IPs in a .qsys file, and we are working with different boards. The configurations...
sstrell
3 years agoWhen you export as .tcl, you shouldn't need any other files to recreate the system. Why do you think you do?
anrfpga
3 years agoApologies for the delay in my response. I have successfully run the script using qsys-script, and it is seemless. I am now able to modify it to fit my requirements. I have initially tried running it from tcl console and it threw an error. Upon seeing the add_component and load_component commands in the generated .tcl, I thought that I would need the .ip files as well. But I understood that it creates new ones in the same relative paths only after running it with qsys-script.
Again, thank you so much. Your help has made my work much easier.
