12 years agoVersion control for the Quartus project
For project built in the Quartus, what files I need to commit to version control system? For HDL and sdc files are straightforward, how about files related IPs? Meanwhile, what is the best app...
11 years ago --- Quote Start --- Hello, It seems due to .qip file generated by Qsys ( .qip will be available in synthesis folder once you generate QSYS design ) not added under version control. Could you try after adding all .qip files ( only .qip, not all Verilog and other files ) generated by QSYS in synthesis and its sub folders? Thanks, Bhaumik --- Quote End --- The .QIP files files are just .tcl files that list the source code generated by QSYS, and any other assignments required. The should be generated from QSYS.
