i'm curious about both codes. the rtl view of the first one show a d flip-flop: iRST - async as reset, iGO as clk, done as data input and go_en as q.
as mhouse1 saids, second code gives an error, i think because the "or" operator ( in verilog we have '|' ). i modified so it didn't give errors:
module verilog_ffd(igo, irst, go, done);
input igo;
input irst;
output go;
input done;
reg go_en;
wire caca;
always@(posedge igo or negedge irst)//on key press event
begin
if(!irst)
go_en <= 0;
else if (done == 1)
go_en <= 0;
else
begin
if(igo) //if go key pressed enable adc
go_en <= 1;
end
end*/
always@(posedge igo or negedge caca)//on key press event
begin
if(!caca)
go_en <= 0;
else
begin
go_en <= 1;
end
end
assign go = go_en;
assign caca = irst | (done != 1);
endmodule but the rtl view show a different behavior ( as expected ): -iGO as clock, data input fixed '1', and reset is ( not iRST and done ). In the second done was an async input.
