11 years ago --- Quote Start --- Actually, I did this before and mentioned this on the first post. Please help :) --- Quote End --- Try the things I mentioned in the 4th post: Did you change the "Allow Any ROM Size for Recognition" setting? Did you change your code to correctly say (* romstyle = "M9K" *) ? Your pasted code is using Verilog comments, which won't do anything. If you do these things, it will work (at least it works for me...)
