11 years ago --- Quote Start --- Sorry, I misunderstood - I thought your problem was that you were using too many registers. But your problem is actually that your ROM is so small that Quartus is fitting the ROM into a handful of registers instead of consuming a M9K memory with them. In order to get Quartus to force it to use M9K, you need to set "Allow Any ROM Size for Recognition" as described on page 12-27 of the HDL coding guidelines previously linked to, and you need to correctly set the romstyle = "M9K" attribute. e.g.
(* romstyle = "M9K" *) output reg data_out;
--- Quote End --- I have written a verilog code for a ROM: module sync_rom (clock, address, data_out); input clock; input [3:0] address; /* romstyle = "M9K" */ output reg [31:0] data_out; always @ (posedge clock) begin case (address) ///// assign values to data_out // 0: data_out = 32'haf123412; endcase end endmodule I have also tried to add /* romstyle = "M9K" */ but when I synthesize and tried to fit my design the number of block memory bits is zero!! and the registers are used!! How can I force the Quartus to synthesize my code as a ROM 16 x 32-bit. I have to mention that I have changed the settings for Synthesis and Analysis to recognize the ROM and RAM of any size! Actually, I did this before and mentioned this on the first post. Please help :)
