11 years agoSorry, I misunderstood - I thought your problem was that you were using too many registers. But your problem is actually that your ROM is so small that Quartus is fitting the ROM into a handful of registers instead of consuming a M9K memory with them.
In order to get Quartus to force it to use M9K, you need to set "Allow Any ROM Size for Recognition" as described on page 12-27 of the HDL coding guidelines previously linked to, and you need to correctly set the romstyle = "M9K" attribute. e.g.
(* romstyle = "M9K" *) output reg data_out;
