15 years agoHello again,
quartus is going to drive me crazy. at first nplttr, no - it didn't work. So I tried to write the controller for my own memory bus first and earned the same: --- Quote Start --- Error (10818): Can't infer register for "fb_data[0]" at SD_controller_FlexBus.vhd(26) because it does not hold its value outside the clock edge --- Quote End --- forLIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY SD_CONTROLLER_FB IS
GENERIC( BUSWIDTH: natural := 8);
PORT
fb_data : inout std_logic_vector(7 downto 0);
fb_addr : in std_logic_vector(19 downto 0);
fb_cs : in std_logic_vector(1 downto 0);
fb_oe : in std_logic;
fb_rw : in std_logic;
fb_ale : in std_logic;
clk : in std_logic;
fb_rx_bd : out std_logic_vector(BUSWIDTH-1 downto 0);
fb_tx_bd : in std_logic_vector(BUSWIDTH-1 downto 0)
END SD_CONTROLLER_FB;
ARCHITECTURE SD_CONTROLLER_FB_architecture OF SD_CONTROLLER_FB IS
BEGIN
PROCESS (fb_ale)
BEGIN
IF (rising_edge(fb_ale)) THEN
fb_data <= "ZZZZZZZZ";
ELSE
fb_data <= "11111111";
END IF;
END PROCESS;
END SD_CONTROLLER_FB_architecture;WHY ? there are 2 damn constants for now ?! At this stage its so easy that I would be able to solder this circuit. cheers, eag1e
