15 years agoThe code doesn't look like a double edge triggered (that is however not synthesizable).
You only have the posedge wb_rst_i in the sensitivity list (for a double edge you should have "posedge ... or negedge ..."). Did you try as I said? My idea is: always @(every signal on the right side of the assignments) aout_comb <= 0; if (wb_rst_i) begin if (...) begin if (...) begin aout <= 1; end else begin ... end ... end ... end elseif (...) begin ... aout_comb <= 1; ... end always @(posedge wb_rst_i) begin aout <= aout_comb; end
