9 years agoVerilog coding
Hi all, I am just start to learn Verilog and immediately had a problem - please take a look at code - why "repeat (10) does not working? I was expected a 5 pulse train at every oop pulse - ...
9 years agoThanks for help,
1. Where I can find specs for Verilog used in Quartus 2 and its specs - what can be used for simulation only etc. 2. Yes I am sending oop signal ,but a problem is that not only repeat() don't work but nether for() and while(): module buff_gen (oop,pls); input oop; wire oop; output pls; reg pls; integer i; initial begin pls = 0; end always @ (posedge oop) begin for (i=0;i<10;i=i+1) begin pls = ~pls; end end endmodule please check attachment with waveform pictures.
