12 years ago --- Quote Start --- Well, you might struggle in an FPGA, as FPGAs can only use either the rising or the falling, not both. --- Quote End --- That's not exactly true. You can use both positive and negative edges but not to toggle the same register. I don't do Verilog, but in VHDL it may look like this:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity posnegcounter is
generic(
WIDTH_COUNT : natural := 8
port(
Clk : in std_logic;
Reset : in std_logic;
Counter : out std_logic_vector(WIDTH_COUNT - 1 downto 0)
end entity posnegcounter;
architecture arch of posnegcounter is
signal poscount : unsigned(WIDTH_COUNT - 2 downto 0); -- only need count half
signal negcount : unsigned(WIDTH_COUNT - 2 downto 0);
begin
process(Clk , Reset)
begin
if (reset = '1') then
poscount <= to_unsigned(0, WIDTH_COUNT - 1) ;
negcount <= to_unsigned(0, WIDTH_COUNT - 1) ;
elsif rising_edge(Clk) then
poscount <= poscount + 1;
elsif falling_edge(Clk) then
negcount <= negcount + 1;
end if;
end process;
counter <= std_logic_vector(poscount + negcount);
end arch;
But still I wonder what the purpose might be?
