14 years ago --- Quote Start --- Judging from the templates, I think VHDL has the same issue. The Altera VHDL templates for RAM with byte enables also requires the body to be changed if the data width is changed. --- Quote End --- No I'm pretty sure in VHDL i could make a generic memory block with byte enables. Something like this:
process(clk)
begin
if(rising_edge(clk)) then
if(we = '1') then
for block_num in 0 to bena_width-1 loop
if(be(block_num) = '1') then
ram(waddr)(block_num) <= wdata((block_num*8)+7 downto (block_num*8));
end if;
end loop;
end if;
q_local <= ram(raddr);
end if;
end process;I haven't tested it, but it should be recognized properly by the synthesizer.
