14 years ago --- Quote Start --- Maybe I'm missing something obvious here, and I have no experience in Verilog, but what is preventing you from putting ifs in the for loop instead of this combinatorial assignment? As for the size when using separate 8-bit blocks, the only limitation I see is that Quartus will use a minimum of bena_width blocks to infer the memory. Yes it can be a problem if you are using large memory blocks and only need a small buffer. --- Quote End --- I think the for loop cannot be inside of the always_ff block. I will try it tomorrow and report back. If it cannot, then the only way to get the ifs in the for loop is to put the always_ff block in the for loop. This results in your original suggestion to create a separate memory for each byte enable. The issue of RAM block waste makes the separate block implementation suitable "sometimes", for example if i need 1kB on a 64-bit bus and my device has M10K blocks then it uses 8 RAM blocks when it should use 1. The reason i want a RAM implementation with working parameters is so that i can write a generic module for a library that uses RAM as one of many components without having to use different code depending on the parameter values. I think the best workaround for now may be to write a set of specific width RAM modules and use generate/if to select the module to use based on the width requested. ps. Judging from the templates, I think VHDL has the same issue. The Altera VHDL templates for RAM with byte enables also requires the body to be changed if the data width is changed.
