14 years ago --- Quote Start --- Can you please give an example in which regard the recommended hdl style uses more RAM than required according to the hardware properties? --- Quote End --- The recommended HDL style does not use more RAM than required. The suggestion by Daixiwen to make Quartus infer a seperate 8-bit wide RAM block for each byte enable uses more RAM than required when the RAM size needed is less than the (block size) * (number of byte enables).
