14 years agoMaybe I'm missing something obvious here, and I have no experience in Verilog, but what is preventing you from putting ifs in the for loop instead of this combinatorial assignment?
As for the size when using separate 8-bit blocks, the only limitation I see is that Quartus will use a minimum of bena_width blocks to infer the memory. Yes it can be a problem if you are using large memory blocks and only need a small buffer.
