14 years ago --- Quote Start --- Could you infer several memory blocks connected in parallel, each one of them handling a 8-bit data bus? Then you use the byte enables to generate write commands only to the relevant blocks. --- Quote End --- Yes, this works fine and is easily implemented by putting the always_ff block inside the generate for loop. Unfortunately this uses a minimum of bena_width RAM blocks regardless of the total size of the RAM because Quartus will not combine them.
