VCS error Error-[URMI] Unresolved modules in cyclonev_atoms_ncrypt.v
What meant by that is using nativelink method in Quartus, for the submodule and see if it is able to simulate instead of using current method. You might need to try and see the if it is possible.
- eman_delete3 years ago
I gave it a try. I created a project using the qip file from the qsys block.
The project was successfully analyzed and elaborated in Quartus. The 3-rd party simulation scripts were generated.
I executed the generated tcl file:
quartus_sh -t balmas_exmple_vcsmx_rtl_verilog.tcl
I got the message that the compilation was successful. I didn't get anything about the elaboration.
Then I tried to elaborate the design using the command:
vcs -debug_access+all nios_sys -kdb -lca
I'm getting a different type of errors. During the design elaboration I see multiple errors:
Error-[UPIMI-E] Undefined port in module instantiation
/<project path>/quartus_prj_nios_sys_only/nios_sys112_verilog/synthesis/submodules/alt_mem_ddrx_controller.v, 1072
Port "local_zqcal_req" is not defined in module 'alt_mem_ddrx_input_if'
defined in
"/<installation path>/quartus_15.0/quartus/eda/sim_lib/synopsys/cyclonev_hmi_atoms_ncrypt.v",
25
Module instance: alt_mem_ddrx_input_if
#(.CFG_LOCAL_DATA_WIDTH(CFG_LOCAL_DATA_WIDTH),
.CFG_LOCAL_ID_WIDTH(CFG_LOCAL_ID_WIDTH),
.CFG_LOCAL_ADDR_WIDTH(CFG_LOCAL_ADDR_WIDTH), .CF ...I can downgrade severity of these errors (-error=noUPIMI-E) , but I cannot downgrade/suppress the errors:
Error-[TMIPC] Many port connections
/<project path>/quartus_prj_nios_sys_only/nios_sys112_verilog/synthesis/submodules/alt_mem_ddrx_controller.v, 1321
Too many module or UDP instance port connections:
Too many port connections are found for instance "tbp_inst" of module
"alt_mem_ddrx_tbp"
Source info: alt_mem_ddrx_tbp #(.CFG_CTL_TBP_NUM(CFG_CTL_TBP_NUM),
.CFG_CTL_SHADOW_TBP_NUM(CFG_CTL_SHADOW_TBP_NUM),
.CFG_ENABLE_SHADOW_TBP(CFG_ENABLE_SHADOW_TBP), .CFG_DWI ...
Module "alt_mem_ddrx_tbp" is defined at
25I see 4 errors and all of them are from the same encrypted file:
