8 years ago(vcom-1600) No feasible entries for subprogram
Dear Good people, I was using following code while simulating it through modelsim, it shows following error : (vcom-1600) No feasible entries for subprogram "avalon_write". Can you guys please give ...
8 years agoThis api_if signal has declaration of mm_mstr_vhdl_if_t which is below type:
type mm_mstr_vhdl_if_base_t is record req : std_logic_vector (MM_MSTR_INIT downto 0); ack : std_logic_vector (MM_MSTR_INIT downto 0); data_in0 : integer; data_in1 : integer; data_in2 : std_logic_vector (MM_MAX_BIT_W - 1 downto 0); data_out0 : integer; data_out1 : integer; data_out2 : std_logic_vector (MM_MAX_BIT_W - 1 downto 0); events : std_logic_vector (MM_MSTR_EVENT_MIN_COMMAND_QUEUE_SIZE downto 0); end record; type mm_mstr_vhdl_if_t is array(MAX_VHDL_BFM - 1 downto 0) of mm_mstr_vhdl_if_base_t; Can you suggest how to declare that in my test program? Thanks
