8 years ago(vcom-1600) No feasible entries for subprogram
Dear Good people, I was using following code while simulating it through modelsim, it shows following error : (vcom-1600) No feasible entries for subprogram "avalon_write". Can you guys please give ...
8 years agoThe api_if parameter in your avalon_write call is not the same types than the one in the procedure declaration. In the procedure declaration:
procedure avalon_write(
addr : in std_logic_vector (AV_ADDRESS_W-1 downto 0);
data : in std_logic_vector (AV_DATA_W -1 downto 0);
signal api_if : inout mm_mstr_vhdl_if_t
) the api_if signal is of type mm_mstr_vhdl_if_t, but in your test bench you declared the api_if signal as a std_logic_vector: signal api_if : std_logic_vector (MAX_VHDL_BFM - 1 downto 0);
