17 years ago --- Quote Start --- Quartus creates a vwf file with a default grid of 10 ns. I'm almost sure your Clock period is 10 ns. and your design is slower. Look for the classing timing analizer or time quest and look for your max. operating frequency. Try with a higher clock period --- Quote End --- Thanks a lot. Yas.You are right, The problem was for higher clock frequency. There was also some problem for some signals setup time and hold time. Problem solved ! ! !
