9 years agovariable initialization help
Hi all, For a process, the variable only take the initial value at the first time the process is running, then it will take the last value of that variable. I am wondering how can I initial the...
9 years agoProcesses dont get "executed" they are in infinite loop starting at time 0.
Do you mean you want to set v1 to init val every time the process is re-evaluated? why not just set v1 to initval before the if statement?
