9 years agoUsing tasks with wait segments in Verilog
Hello, I have a problem with using wait segments in my task. I am trying to test a deserializer, that has to work with a specific format. I want to give the full byte to send to the task, then ...
9 years agoThe use of 'automatic' means the verilog compiler/simulator must make the task re-entrant, so it must copy all input/outputs to temp variables during execution. So this probably means you are calling the task multiple times in parallel, while older invocations are still executing, because of your builtin time delays.
As an example, in old style verilog, I have the task just reference the module signals in its called context, and not pass everything as arguments. I also don't call the task again until I know the existing call has finished (which in my case calling it multiple times in parallel does not make any sense). Example:
reg sd_dat_adr = 0;
reg sd_dat_wen = 0;
reg sd_dat_din = 0;
wire sd_dat_dout;
task rd_buf;
input fradr;
input toadr;
integer i;
begin
@(posedge clk)# TPD ;
$write("\n");
for (i = fradr; i <= toadr; i = i+1)
begin
sd_dat_adr = i;
sd_dat_wen = 0;
sd_dat_din = 0;
if (sd_dat_adr % 16 == 0) $write("%h:", sd_dat_adr);
$write(" %h", sd_dat_dout);
if (sd_dat_adr % 16 == 15) $write("\n");
end
$write("\n");
end
endtask // rd_buf
And then in my testbench I just call the task when needed: initial
begin
init_card(10);
rd_buf(0,511);
delay(250);
$finish;
end
