CBRUN12
7 years agoUsing submodule-naming-pattern[=<value>] for ip-generate with script
Hi everyone, I have generated an altera_soft_lvds IP from the IP Catalog of Quartus Prime and I got three useful files : altera_soft_lvds.qip altera_soft_lvds.v altera_soft_lvds_0002.v (located...
CBRUN12
7 years agoHi @JwChin
I would like to use the command lines instead of the GUI.
By using the command lines, the number of generated files is not the same as GUI (total of 1 .v file with command lines instead of 2 .v files)
- JonWay_altera7 years ago
Would you check if running the GUI would generate the same number of files? I want to know what is the results of GUI vs command line.
