9 years agoUsing SignalTap to capture high rate clocks?
Hello, I would to know how accurate SignalTap is when capturing signals such as an 80-Mhz clock from a pll that is used to drive logic? When I view such a signal I see a non 50-percent duty cycle clo...
9 years ago --- Quote Start --- Hi corestar, Thanks for adding in your comments. I'm trying to view an 80Mhz signal that drives my HDL module. The signal is from a pll with an input clock of 80Mhz. --- Quote End --- This sounds like a clock? why are you trying to signaltap it? it either works or it doesnt. Usually you would capture the locked signal, or output to an LED or something.
