9 years agoUsing SignalTap to capture high rate clocks?
Hello, I would to know how accurate SignalTap is when capturing signals such as an 80-Mhz clock from a pll that is used to drive logic? When I view such a signal I see a non 50-percent duty cycle clo...
9 years agoHi corestar,
Thanks for adding in your comments. I'm trying to view an 80Mhz signal that drives my HDL module. The signal is from a pll with an input clock of 80Mhz.
