9 years agoUsing SignalTap to capture high rate clocks?
Hello, I would to know how accurate SignalTap is when capturing signals such as an 80-Mhz clock from a pll that is used to drive logic? When I view such a signal I see a non 50-percent duty cycle clo...
9 years agoIs there a reason why you need to see the clock in SignalTap? Remember, it's best if your sampling clock is twice the frequency of what you're monitoring. So with an 80 MHz sampling clock used to look at an 80 MHz clock, it may miss edges, which is what you are seeing.
