13 years agoI implemented it myself with VHDL like this:
----------------------------------------------------- ----------------------------------------------------- library IEEE; use ieee.std_logic_1164.all; entity RAM is port( clock: in std_logic; data: in std_logic_vector (7 downto 0); write_address: in integer range 0 to 2047; read_address: IN integer range 0 to 2047; we: in std_logic; q: out std_logic_vector (7 downto 0) ); end RAM; architecture rtl of RAM is type mem is array(0 to 2047) of std_logic_vector(7 downto 0); signal ram_block : mem; begin process (clock) begin if (clock'event and clock = '1') then if (we = '1') then ram_block(write_address) <= data; end if; q <= ram_block(read_address); end if; end process; end rtl; ----------------------------------------------- ----------------------------------------------- As you see, this is a dual port RAM. Is it possible to use In-System Memory Content Editor for this dual-port RAM? Thanks in advance
