12 years agoUsing set_input_delay? When to use -add_delay, -rise, and -fall?
Hello, I was doing some research on the Multicyle Exceptions and found a great example:
http://www.altera.com/support/examples/timequest/exm-tq-sdc-exceptions.html?gsa_pos=4&wt.oss_r=1&wt.oss=set_multicycle_path examples When I was looking over the example I decided to download the Quartus .qar archive. I then looked at the .sdc file and it was different that the example on the page. For example the web page has: # Constrain the input and output ports set_input_delay -clock clk_in 1.2 [get_ports data_in] set_input_delay -clock clk_in 1.5 [get_ports async_rst] set_output_delay -clock clk_in 2 [get_ports data_out] But the .sdc file in the .qar has: # ************************************************************** # Set Input Delay # ************************************************************** set_input_delay -add_delay -rise -max -clock clk_in 1.500 [get_ports async_rst] set_input_delay -add_delay -rise -min -clock clk_in 1.500 [get_ports async_rst] set_input_delay -add_delay -fall -max -clock clk_in 1.500 [get_ports async_rst] set_input_delay -add_delay -fall -min -clock clk_in 1.500 [get_ports async_rst] set_input_delay -add_delay -rise -max -clock clk_in 1.200 [get_ports data_in] set_input_delay -add_delay -rise -min -clock clk_in 1.200 [get_ports data_in] set_input_delay -add_delay -fall -max -clock clk_in 1.200 [get_ports data_in] set_input_delay -add_delay -fall -min -clock clk_in 1.200 [get_ports data_in] So here's my question, why is there a -add_delay and why is there a -rise and -fall? Are those required? Thanks, joe
