Altera_ForumHonored Contributor18 years agoUsing SDRAM with a peripheral Hi, I am trying to connect SDRAM to my peripheral device directly and I read the postings on the forum which says I can use "user logic" to connect to SDRAM controller. I tried writing my user lo...Show More
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
