15 years agoAs wtoner said, in Ubuntu 10.10 64bits it does not work. Well, after I did rename the librairies with _old as jrierab said, I got that message :
--- Quote Start --- quartus: symbol lookup error: /usr/lib32/libXi.so: undefined symbol: XESetWireToEventCookie --- Quote End --- I have found what to do here ( ubuntuforums.org/showthread.php?t=1448839) about the Shake software, with the same error. This is what I did : --- Quote Start --- * go to [packages.ubuntu.com/karmic/i386/libxi6/download] and download libxi6_1.2.1-2ubuntu1_i386.deb * DON'T INSTALL IT. This is old version of libXi and your system allready has newer. You need this version only to run quartus. * uncompress libXi.so.6.0.0 in to /usr/lib32/ * make symbolic link libXi.so.6 => libXi.so.6.0.0 * run quartus * Enjoy. --- Quote End --- Instructions from elt128's post.
