15 years ago --- Quote Start --- Just download file from the slacker's post and copy it to the library directory:
cp libXi.so.6.0.0.txt /usr/lib/libXi.so.6.0.0
ln -s -f /usr/lib/libXi.so.6.0.0 /usr/lib/libXi.so.6
--- Quote End --- Didn't wok for me in Lynx 64bit with libXi.so.6.1.0. Trying to install 10.0sp1_quartus_free_linux.sh and I was able to install 10 before sp1 in Koala 64bit fine. Koala has the 6.0.0 version of libXi.so. Slacker's copy failed, copying from my Koala drive billt@vblynx64:/tmp$ ls -l /usr/lib/libXi.* -rw-r--r-- 1 root root 153588 2010-03-22 16:17 /usr/lib/libXi.a lrwxrwxrwx 1 root root 23 2010-09-04 14:44 /usr/lib/libXi.so -> /usr/lib/libXi.so.6.0.0 lrwxrwxrwx 1 root root 23 2010-09-04 14:17 /usr/lib/libXi.so.6 -> /usr/lib/libXi.so.6.0.0 -rw-r--r-- 1 root root 38384 2010-09-04 13:53 /usr/lib/libXi.so.6.0.0 -rw-r--r-- 1 root root 63864 2010-03-22 16:17 /usr/lib/libXi.so.6.1.0 lrwxrwxrwx 1 root root 23 2010-09-05 20:05 /usr/lib/libXi.so.6.noaltera -> /usr/lib/libXi.so.6.1.0 lrwxrwxrwx 1 root root 14 2010-09-04 09:47 /usr/lib/libXi.so_noaltera -> libXi.so.6.1.0 I copied 10.0 build 218 as installed from Koala machine and that seems to start fine with Slacker's fix. If I put libs back to Lynx's 6.1.0 version billt@vblynx64:/tmp$ ls -l /usr/lib/libXi.*-rw-r--r-- 1 root root 153588 2010-03-22 16:17 /usr/lib/libXi.a lrwxrwxrwx 1 root root 14 2010-09-04 09:47 /usr/lib/libXi.so -> libXi.so.6.1.0 lrwxrwxrwx 1 root root 23 2010-09-05 20:05 /usr/lib/libXi.so.6 -> /usr/lib/libXi.so.6.1.0 -rw-r--r-- 1 root root 43272 2010-09-05 21:01 /usr/lib/libXi.so.6.0.0 -rw-r--r-- 1 root root 63864 2010-03-22 16:17 /usr/lib/libXi.so.6.1.0 lrwxrwxrwx 1 root root 23 2010-09-04 14:17 /usr/lib/libXi.so.6.altera -> /usr/lib/libXi.so.6.0.0 lrwxrwxrwx 1 root root 23 2010-09-04 14:44 /usr/lib/libXi.so.altera -> /usr/lib/libXi.so.6.0.0 quartus 10 again seems to works fine. Though I have not yet got an install to run so I'm not at 10SP1. Does this only affect installer??
