16 years agoJust in case someone needs the libXi.so.6.0.0 required to run eclipse, I've attached it...with a "phony" .txt attachment suffix that you'll have to rename.
Cheers, -slackerJust in case someone needs the libXi.so.6.0.0 required to run eclipse, I've attached it...with a "phony" .txt attachment suffix that you'll have to rename.
Cheers, -slacker
