Using Profiling to measure the Kernel Execution Time
- 5 years ago
"CL_PROFILING_COMMAND_QUEUED" returns the time at which the command was added to the queue. There is no guarantee that the command is executed as soon as it is added to the queue since there might be some other commands already in the queue (e.g. non-blocking data transfers or clSetKernelArg() commands that were queued before the kernel launch). At the same time, even if there are no other commands in the queue, there is some queuing/launch overhead associated with all OpenCL commands, including transfer of metadata via PCI-E. General consensus is that if your kernel execution time is less than at least some hundreds of us, the command queue/launch overhead could very well become the performance bottleneck and there is probably no point in accelerating such application on a PCI-E-attached accelerator.
Hi ,
Please let us know whether the solution mentioned in the discussion was adequate and any further support is required on this issue.
Thanks and Regards
Anil
