12 years agoUsing PLL "lock" signal as the async reset in Verilog
If I want to use the PLL "lock' signal to work as an async reset, the "lock" signal will keep low after the FPGA is powered and goes high after a duration. If I won't reset my PLL, then it means "loc...
12 years ago --- Quote Start --- Thanks very much, Dave. --- Quote End --- You're welcome! Cheers, Dave
