11 years ago --- Quote Start --- The problem may be related to using a hex file. I was hinting at using a mif file with hex to see if that works instead (you could make a small mif file to begin with and just try and read a few values). I can vouch for mif files with hex values simulating while other types of file do not simulate correctly. It may help you eliminate other problems from the process. --- Quote End --- Ahh ok I see now, you're suggesting I use a mif file, but change the DATA_RADIX to hex values?
