15 years ago --- Quote Start --- @pletz, Does this mean I can no longer use megafunctions in my design and simulate them. Surely not! :( @nplttr, I am trying RTL simulation. I'll try gate level simulation right now! --- Quote End --- Hi, we are only talking about the LPM function. With Quartus 10.0 they ar no longer available in the Megawizard. As long as you will not change the LPM you can run P&R. If you need to change same you have to go back to version 9.1. Here what you can found in the release notes of Quartus 10.0: The MegaWizard Plug-In Manager no longer supports the following megafunctions: ALT3PRAM, ALTACCUMULATE, ALTGXB, ALTSHIFT_TAPS, ALTSQRT, LPM_ABS, LPM_ADD_SUB, LPM_AND, LPM_COMPARE, LPM_CONSTANT, LPM_COUNTER, LPM_DECODE, LPM_DIVIDE, LPM_FF, LPM_FIFO+, LPM_INV, LPM_LATCH, LPM_MUX, LPM_OR, LPM_RAM_DP, LPM_RAM_DP+, LPM_RAM_DQ, LPM_ROM, LPM_SHIFTREG, and LPM_XOR. You can compile designs that include the above megafunctions in the Quartus II software version 10.0, but you cannot create new instances or edit existing variations of these megafunctions. Kind regards GPK
