9 years agoUsing different color of signals in ModelSim
Hello everyone, I have a simple (4x1) multiplexer that I want to simulate with modelsim. Now, I have given each input signal a different color and I want the output to be of different color each time a channel is selected. For example, if channel 1 is red then when the (select) signal is (00) and channel one is chosen the output is also red and when (01) the output switches to a different channel of a different color. Is it possible to accomplish this task? Thank you for your help. Of course for a (4x1) system it is easy to distinguish the channels, but difficulties arise when I want to use an (8x1) and (16x1) systems.
1 Reply
This is something you may be able to do by defining custom types in modelsim.
Look at the radix-define entry in the command reference manual.
