Using command line tool to generate .cdf file from (jic and sof files)
I have the hardware files (.jic and .sof) .How to use the command line tool in Quartus® Prime software to generate (.cdf) file
Thanks for your help!
- AnandRaj_S_Intel
Please use Programmer tool GUI to generate a Chain Description File (.cdf) .
let me check if it is possible to generate cdf from command line.
Anand
- OAziz
Hello Anand,
Thank you for your answer, I'm using the GUI to generate a Chain Description File (.cdf) for manual test . But I need to automate this. The software will generate the CDF file for each board according to board version.
Thank you for your Help.
Osama
- AnandRaj_S_Intel
.cdf can only be generated using GUI.
However we are program fpga without cdf file using device indexing.
>quartus_pgm -m JTAG -o p;<file name>.sof@1
For scripting help type quartus_sh --qhelp to get scripting help from GUI.
Anand
- OAziz
Thank you very much.
Osama
