--- Quote Start ---
Thanks guys. The hold time optimization settings were all checked using timing optimization advisor...
Here are two screen shots I took for the hold time violations I got in the latest compilation. Now the problem actually shifted to the rising edge of the clk (clk_7m). The timing report is also attached in the zip file.
Any clue from here?
--- Quote End ---
Hi
How does the clock paths looklike ?
Why are the launch and latch edge identical and where does the large clock skew (0.8 ns) comes from ? Is the clk7m defined as global ?
Kind regards
GPK
