--- Quote Start ---
The Technology Map Viewer should show correctly, how the inversion is implemented. As far as I remember, previous FPGA families didn't have a local clock inversion.
To understand the reason for timing violations, you can check what's between the registers.
--- Quote End ---
Thanks guys. The hold time optimization settings were all checked using timing optimization advisor...
Here are two screen shots I took for the hold time violations I got in the latest compilation. Now the problem actually shifted to the rising edge of the clk (clk_7m). The timing report is also attached in the zip file.
Any clue from here?
