9 years agoUsing a SPI module.
I have a SPI module. Code: But how do I actually use it? In order to write to it I should load some data to SPI_Wr_Data and apply high signal to SPI_Wr_Start_Trig. When the trigger applied the da...
9 years agoHi Tricky,
Let me put it this way - do you have any working SPI module? If so - can you provide a practical example how to use it? I don't know the origin of SPI core I provided but I know for sure it's a working code cause it was used before. No I can't look at the previous use of the module - i don't have it.
