9 years agoUsing a SPI module.
I have a SPI module. Code: But how do I actually use it? In order to write to it I should load some data to SPI_Wr_Data and apply high signal to SPI_Wr_Start_Trig. When the trigger applied the da...
9 years agoYou should read the documentation provided with the core.
If you dont have documentation, then find another core, or investigate how this one works. Where did you get this code from?
