ThomasTessier
3 years agoUsing 2 inputs to Clock MUX doesn't result in correct answer
I have a design were I am trying to use the Input Clock MUX to Switch between two input pin clock ports. The PLLs are in platform designer and I get the following warning:
Warning: test_system_qsy...
ThomasTessier
3 years agoAny thoughts on why this simple example doesn't compile?
TomT...
