ThomasTessier
3 years agoUsing 2 inputs to Clock MUX doesn't result in correct answer
I have a design were I am trying to use the Input Clock MUX to Switch between two input pin clock ports. The PLLs are in platform designer and I get the following warning:
Warning: test_system_qsy...
ThomasTessier
3 years agoSo are those two tabs in Quartus or Platform Designer? I see the "System Contents" and "Parameters" tabs in Platform Designer. They are showed below. If this isn't what you wanted please let me know:
The rest of the settings are defaults.
TomT...
