ThomasTessier
3 years agoUsing 2 inputs to Clock MUX doesn't result in correct answer
I have a design were I am trying to use the Input Clock MUX to Switch between two input pin clock ports. The PLLs are in platform designer and I get the following warning:
Warning: test_system_qsy...
sstrell
3 years agoCan you show your connections in the System View tab and the component connections that are enabled with the options you've selected in the Block Symbol tab?
